CompCam 12-206-2?
Old Mar 21, 2005 | 12:19 PM
BlackMagic's Avatar
Car: 1986 Firebird
CompCam 12-206-2?
I do not know anything when it comes to cams into motors, and would like to get some help from yall. I have a Comp High Energy Cam 12-206-2, and flat tap lifters. Will this cam work in my 305 TPI. Here are the specs for it...please any help will help greatly.
Basic Operating RPM Range: 1,200-5,200 RPM
Intake Duration 050 inch Lift: 212
Exhaust Duration 050 inch Lift: 212
Duration at 050 inch Lift: 212 int./212 exh.
Advertised Intake Duration: 260
Advertised Exhaust Duration: 260
Advertised Duration: 260 int./260 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.440
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.440
Valve Lift with Factory Rocker Arm Ratio: 0.440 int./0.440 exh. lift
Lobe Separation (degrees): 110
Intake Valve Lash (in): 0.000
Exhaust Valve Lash (in): 0.000
Computer Controlled: No
Grind Number: CS 260H-10
Old Mar 21, 2005 | 12:22 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Uhhhhhhhhhhh, thats a lot of duration..... Oh wait, just noticed it had two, I thought it was 260 @ .50 lift. I was like wow.....that 305 is gonna suffocate...
Old Mar 21, 2005 | 12:25 PM
BlackMagic's Avatar
Car: 1986 Firebird
So does that mean the the cam will not work, or will it?
Old Mar 21, 2005 | 01:02 PM
pasky's Avatar
Sorry, I have no idea, I just thought I had seen it was 260 @ .50 and was going to tell you no way that would work. I know the cam specs there will work with your 305, but im not familiar with a 305 and not sure how it would act or perform.
Old Mar 21, 2005 | 08:18 PM
BlackMagic's Avatar
Car: 1986 Firebird
come on guys, i need to know. would like to get it pulled out and put in if it does fit this weekend!
Old Mar 21, 2005 | 08:56 PM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
If that's the hi energy 260 comp cam, it's a pretty mild cam. I've never tried one on a 305 but I've noticed that other 305 guys are using larger cams without too much trouble.
It seems like it should work.
ChaseDale3and8
Sep 1, 2015 01:49 PM
RacingGreenSC
Aftermarket Product Review
Nov 14, 2001 05:00 PM
Dirtybird355
Aug 25, 2001 05:15 PM
Hype
Dec 27, 2000 09:35 AM
