Antifreeze Additive??????
Old Jul 19, 2001 | 04:01 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Lately in this 90-100* weather, my car has been heating up driving around town around (220* and climbing, that's when I turn my heat on). I have a new aluminum radiator, 160*stat and new radiator cap. The coolant level is fine and the car normally runs 170-180*. I have heard of this stuff called Fast Forward ( I think that is right not sure), supposedly lowers temp. I have heard from one person that it works, anyone else used this or other additive.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER, NO CAT
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
2:73 GEARS
Rebuilt 700R4, with manual valve body
B&M Megashifter
Soon to be installed
3:73 Richmond Gears and 3" Hooker Aero Chamber
Corvette Servo & .500 boost valve
15.61@ 95.2mph G-Teched, 1-2 shift slippage
"There is nothing more addicting than speed"
Old Jul 19, 2001 | 05:10 PM
ede's Avatar
ede
there are several, NOS makes it, water wetter is another, royal purple makes it. it works but it isn't a cure all for a bad cooling system
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Jul 19, 2001 | 05:25 PM
Scrams84Z's Avatar
Car: 1984 Z28
Engine: Custom built 383
Transmission: Tremec 3550
Watter Wetter and such basically helps remove air bubbles from your coolant. Removing the air bubbles allows the coolant to transfer heat more efficiently. I have heard some say it works, I have heard others say it made no differance. As mentioned above, it is no substitute for a poor performing cooling system. Try running a mixture of 20% antifreeze/80% distilled water with a bottle of Water Wetter or something similar. Water has better heat transfer properties than antifreeze, but the antifreeze provides lubrication for your water pump. Check your water pump, make sure your air dam is in place. Lastly, you may have a bad Thermostat, new or not. Also, are your fans kicking on?
'84 Z28 w/ T-tops, 420HP Stroked 383, Trick Flow aluminum heads, Tremec 5 speed, 3.73 posi rear, Edelbrock 750 cfm carb, Dual Snorkel air cleaner w/ K&N filter, Edelbrock headers & 3" exhaust, Edelbrock Strut Tower Brace, Hotchkis LCA's and Panhard Rod, there is much suspension work to come.
1979 Corvette - Black/Black - 350 CI L82 w/ MM4 close ratio 4 speed manual
"Smoke 'em if you got 'em"
Old Jul 19, 2001 | 10:44 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
I just want to emphasize what scram said. Try running a thinner mix of AF to water. Guido's car was running hot after he got the blower on just a few weeks ago. He dropped the AF mix from 50/50 down a good bit and his temps went from 220-230 to 190-200.
Never overlook the simple things. It's also not out of the question that your new rad cap is bad outright, but thats doubtful. Or a bad t-stat. Or loose hose clamps.
Ed Maher - Moderator @ The TPI & Carb Boards
92 Z28 Convertible - Quasar blue / Tan top
LB9 4L60 GU2 G80 - stock, soon to be sleeper
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
Old Jul 19, 2001 | 11:00 PM
Brian K's Avatar
Flush the system and adjust your mix.. I use watter wetter here in FL... For 6 bucks that snake oil can't hurt.. Is worth a shot...
PurelyPMD
May 5, 2016 04:57 PM
blackz281le
Jan 11, 2016 07:51 AM
Giocio
Oct 1, 2015 12:20 PM
WhteRbt
Sep 21, 2015 09:48 AM
bryan623
Sep 19, 2015 10:13 AM
