How easy would it be to remove all the components of the stock AC from 91' Z28?
Old Jul 19, 2001 | 08:45 PM
shaocaholica's Avatar
I never use the AC in my car and I also need to replace the blower since its really weak. The AC is just was waste of space and extra weight. How long will it probably take to remove all of it? Are there any special tools I need?
Old Jul 19, 2001 | 10:14 PM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
A friend of mine just took his off last Sunday and it didnt take that long from what I remember. I was removing my somg stuff so I wasnt completely paying attention but they did not need any fantsy tool all you need is an A/C delete pulley to replace the condensor. I am not sure of the part nember maybe you can find it on the Technical Article section of this fine webpage. Oh yea maybe 1 hour or so for removal.
Old Jul 19, 2001 | 10:38 PM
maksik7's Avatar
Don't you need the AC professionaly discharged since all the contents are under very high pressure and will blow out when you disconnect the hoses?
Old Jul 19, 2001 | 11:01 PM
Brian K's Avatar
Keep the AC... Resale it will help, plus one day you will appreciate having it, say it was raining mid summer.. Just remove the belt at the track...
Old Jul 20, 2001 | 05:57 AM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
<font face="Verdana, Arial" size="2">Originally posted by Brian K:
</font>
He can't remove the belt...he has a serpentine setup.
Old Jul 20, 2001 | 07:52 AM
clemsparks's Avatar
Car: 1983 Z28
Transmission: WCT5
I've seen it done lots. I don't necessarily recommend it, but do you really need power steering and coolant for that short quarter mile? Like I said, I DON'T recommend it, but have seen it done.
You should take the car to have the system evacuated before you open it though, for the environment's sake.
Clem
SCCA TransAm Series Race Mechanic/CrewChief
1983 Z28 with LG4, 5 speed, and (unfortunately) T-tops
1983 Z28, NO T-tops, (unfortunately) Auto Transmission (hopefully not for long)
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
NinjaNife
Aug 23, 2015 11:49 AM
kyleb24
Aug 15, 2015 08:24 AM
3rdgenparts
Aug 8, 2015 07:09 PM
