Quick EGR question
Old Jul 20, 2001 | 12:38 PM
wiggy'sIROC's Avatar
Car: 1986 IROC
Engine: 305 going to 355
Quick EGR question
If I remove all of my smog stuff will the EGR still function? If not, what do I need to do with it?
Mark
1986 IROC LG4 "Bone Stock" (for now)
Old Jul 20, 2001 | 01:09 PM
ATOMonkey's Avatar
Use a block off plate in the manifold or the head.
Old Jul 20, 2001 | 01:41 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
And yes, the EGR will still function if you remove your other smog equipment. It is controlled by the ECM and is based on various "constraints" within the programming.
Also, if you DO wish to remove the EGR, you will have to disable it in the eprom and turn off the diagnostics. The best wasy to disable it is to adjust the "EGR MAT Temp Enable" to x'FD.
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
camaroken83
Aug 10, 2015 11:35 AM
