msd distributor with zz4 cam?
Old Mar 24, 2005 | 09:26 PM
1meanGTA's Avatar
Car: 1987 GTA/1998 Explorer
Engine: 355, trick flow heads, zz409 cam, 3
Transmission: 700r4, shift kit, valve body
Axle/Gears: precision 3.73's, auburn diff
my car recently died on me and wouldnt restart after seemingly running fine, i tracked it down to the distributor gear with a lot of help from the members here. im running a zz4 cam, with an msd distributor, and the zz4s need "melonized teeth." does msd carry a gear that will work with a factory roller cam, or will a gmpp part fit on my msd?
Shaun
Old Mar 24, 2005 | 10:16 PM
BOTTLEDZ28's Avatar
Transmission: A4
what is a melonized teeth gear? I have never heard of that in my life. WHat is so special about the gear on the back of the ZZ4 cam? I cant answer your question but I know who can. Go to the MSD message forums and ask your question their. I PROMISE you will get an answer there is no time from one of MSD's techs http://www.msdignition.com/forums/in...load/index.php
Old Mar 25, 2005 | 10:27 PM
1meanGTA's Avatar
n/m i talked to the guy i got the car from and he says its a tpis zz409 cam, waiting on the specs now. posted at msds site and a moderator said melonized gears are used for most all cams, dont know why the gmpp page said it like it was something special.
Old Mar 26, 2005 | 12:34 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
GM made a lot of distributors before 1987. That's why it's "special".
If MSD doesn't think they're "special", have they explained why the ZZ409 chewed it up?
lt500r55
Sep 1, 2021 01:30 PM
beastin91rs
Oct 9, 2015 07:38 AM
italiano67
Aug 31, 2015 06:04 PM
Thornburg
Aug 30, 2015 08:05 AM
midias
Aug 15, 2015 05:07 PM
