no blowing
Old Mar 25, 2005 | 10:21 AM
90' formula TBI's Avatar
Car: 1990 Firebird Formula TBI 305
Transmission: I'm not sure.
no blowing
My air conditioner does not work. When i try to turn on the heater or the A/C nothing comes on but the radiator fan. I know the hoses to and from the heater core are taken out because the core leaks, but shouldnt the blower motor still come on. what should i do to fix this.
Old Mar 25, 2005 | 12:08 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
The blower motor probably froze up or burned out. The other less likely possibility is that there is a wiring fault, bad contact, dead fuse, etc. With a volt meter, you can measure and see if theres voltage present when the blower is supposed to be active. If theres power, then the blower motor is toast.
Old Mar 25, 2005 | 12:15 PM
Thanx ill give it a try
blackz281le
Jan 11, 2016 07:51 AM
Fanatic1074
Oct 2, 2015 03:47 PM
86IROC112
Sep 28, 2015 08:17 PM
Nighthawkf-117
Sep 24, 2015 02:47 PM
90formulaVortec
Sep 3, 2015 09:26 AM
