1st time timing the motor
Old Mar 25, 2005 | 09:09 PM
84taowner's Avatar
Car: 1984 T/A
Engine: L69
Ok, so I finished up the rebuild of the 305 in my 84' T/A and droped the motor in and after I got everything reinstalled I got a chance to start it up for the first time. It started right up no problem and after I worked out a few new engine bugs I started goofing with the timing to try and set it to the cams specs. Cam specs say to set the motor at 5 degrees BTC before you drop in the dizzy, which I did and then once the motor is running advance the dizzy untill 14 degrees is met with a timing light, no problem, I understand that but what I dont understand is the damn VECI label says to disable the EST by disconnecting the 4 wire connector on the dizzy, and then the shop book says there is a one wire connector you need to disconnect. The only 4 wire I see on the dizzy is the main harness and the car wont start with that not connected and I cant find a one wire disconnect, so which is it?? The book has a pic of the one wire but I cant find it in the car, mabey its for TPI motors and not mine?? I went back with the CC q-jet with my new manifold.
If someone could just show me a pic of this 4 wire connector, it would sure help. I guessing that you disconnect the wire BEFORE you start the engine?
Old Mar 26, 2005 | 03:26 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Set timing Connector
The set timing connector is located hanging out of the large wiring harness that goes over the HVAC housing, you might mistake it for a fuse holder.
ESC module is to the left of the wiper motor, behind brake booster.
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
