will these valves work on 416 heads?
Old Mar 26, 2005 | 01:32 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
I found these valves of ebay for sell, seems like a really good deal. It say that they will work on a 305 but i wanna make sure before i buy them. Heres the link:
http://cgi.ebay.com/ebaymotors/ws/eB...964338880&rd=1
Old Mar 26, 2005 | 08:36 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
Anyone?
Old Mar 26, 2005 | 09:37 PM
84 Restore's Avatar
Car: 1984 Z28 camaro HO Gun metal Gray
Engine: 305,L69 H.O. rebuilt
They will work. JUst put some in my 416's. You will have to have the valve seats cut for the intake valves and get the combustion camber unshouded after too. Those valves will work great on ported and polished heads. That is a really good deal tho. I paid 68.00 for just the intake another 68.00 for the exhaust. I would ****** those up. My only concern is they do not give the maker of the valves.
Old Mar 26, 2005 | 10:02 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
What does that mean?
Old Mar 26, 2005 | 10:19 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
That's a heck of a deal for SS valves...
Your 416 heads have smaller diameter seats to seal smaller diameter valves...just installing larger valves, does nothing to increase the seat size...so in order to take advantage of more flow. you need larger seats installed, or have the original seats enlarged(if possible)
i/e, the intake seats on your 416's are cut for 1.85inch valves...now you have a set of 1.94inch valves...the "hole" needs to be bigger to allow more flow to take advantage.
That really is a *** price for SS valves..heck, even if they are only 10% better than stock valves, you.'re stlll ahead of the game.
I think I'll do some bidding
Oh, unsrouding the chambers for the larger valves...instead of me explaining, do sme dearching on porting heads article by Sitting Bull
Old Mar 26, 2005 | 10:26 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Okay, I did notice one thing loooking at them a bit closer, they only have the single groove keeper...means you won't have a place for the standard leaky valve stem seals...so you'll have to have the 416's cut for positive seals where some material is machined off the valve boss on the head so a new style seal is used..it's much better than the old way anyways...but just FYI
Old Mar 28, 2005 | 12:51 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Fel-Pro makes a positive seal that fits the factory guide boss without cutting them.
NBrehm
Aug 25, 2015 11:49 PM
lakeffect2
Aug 23, 2015 08:44 AM
89mulletbird
Aug 12, 2015 07:08 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
