msd ignition
Old Mar 27, 2005 | 06:04 PM
Orange-Z's Avatar
Car: 84 Trans Am
Engine: moded 350
Transmission: World Class T5
Axle/Gears: 99 Z28 10 bolt w/ strange 4.10
msd ignition
i have an 86 z28 with TPI
i am converting over to the small cap distributor
i have this distributor
http://msdignition.com/dist_2.htm
the 6a box and a blaster 3 coil pack
so i had to convert my wiring harness inorder to install the msd system
but i am not sure that i have it hooked up right. like the wires that come from the msd box to the distributor
normally that wire would go from the distributor to the coil pack then back into the wiring harness but im not useing that kinda of coil im using a blaster 3. so i need to know how i need to hook these wires up. right now i have the purple and green wire comming from the box spliced into the connector, then pluged right into the distributor, but i am not sure if that is correct.
i hope someone can understand what i am trying to say so i can get some help
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
meeklay812
Oct 1, 2015 03:46 PM
RedLeader289
Sep 23, 2015 06:50 AM
