non third gen question
Old Jul 23, 2001 | 07:46 PM
thefastest's Avatar
I have a 1990 chystler new yorker. when I turn the key it takes a while(about 15 sec.) to turn on, when it turns on I have to keep my foot on the gas because it will turn off if I dont. I recently replaced the fuel filter(after the problem started)the plugs the wires the distributor cap & rotor. what could be the problem.
P.S. its a 3.0 v6 mpfi
Old Jul 23, 2001 | 08:03 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
I would reccomend checking everthing 1 more time. Its possible the fuel pump is going or plugged injectors. If you dont find the problem replace the computer. The ECM's in dodges are crap and crap out alot. I worked in my parents shop for two years and the computer is the 1st that is changed when a problemd chystler appeared and it fixes it 90% of the time.
SSC
Could also be the TPS but that would be more of a highway driveability problem unless its really out of whack.
[This message has been edited by SSC (edited July 23, 2001).]
Old Jul 23, 2001 | 09:15 PM
thefastest's Avatar
I forgot to mention that the engine shakes very badly while on
Old Jul 23, 2001 | 11:00 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
<font face="Verdana, Arial" size="2">Originally posted by thefastest:
I forgot to mention that the engine shakes very badly while on</font>
Still, try the things I mentioned and see if it flys.
Good Luck!
SSC
Frozer!!!
Jan 19, 2024 04:55 PM
69 Six Pack
Oct 5, 2015 07:51 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
