Oil pressure gage is dancing!
Old Mar 28, 2005 | 12:38 AM
GravyGut's Avatar
Car: 1988 Camaro
Engine: 305 TBI
Transmission: Auto w/ overdrive
At a stop, the oil pressure gage dances/flutters allot. Is this normal?
Old Mar 28, 2005 | 03:06 AM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
No it isn't, Check the sensor, that ususally is the cause.
Old Mar 28, 2005 | 12:00 PM
sellmanb's Avatar
Car: '86 Berlinetta
Yep. The oil pressure can be low due to a bad oil pump. The oil pump rarely ever craps out though. The most common cause of low oil pressure is bearing clearances, or a spun bearing (or two or three ).
The most common cause of the gauge reading low oil PSI is simply the oil pressure sending unit. And after that, the gauge meter could be faulty.
You can have your oil pressure checked for accuracy with a mechanical oil pressure gauge. Or you can just get a new oil pressure sender. Most likely, like stated by HalfInchWrench, it's usually the sensor.
89GTAOz
May 16, 2020 09:31 AM
Prodigious
Oct 4, 2015 11:20 PM
solocus
Sep 2, 2015 12:14 PM
355sbcTPI
Aug 19, 2015 04:38 PM
