What heads & internals to get for 350 w/ LT1 intake swap?
Old Mar 24, 2005 | 05:18 PM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
I'm not doing this right now or in the super near future, maybe next year or so. I want to put a 350 in my Trans Am, but I also want to make it low 13's /12's with slicks. But I need some pointers on heads/pistons and crank.
So here's what I got so far in my head:
1) LT1 intake courtesy of John McMillan
2) LT4 or ZZ4 hot cam
3) 3.73 gears
4) TQ conv.
5) SFC's
6) LCA's
7) hooker long tubes and a cutout
How does that sound so far, any changes or recomendations for me regarding any of those?
I got this far, but I am not sure what heads would be good. What heads would flow like the LT4 heads? What about pistons, which should I go with? Would L98 or LT1 be ok? And the crank, would the L98's or LT1's be fine?
Last question, the SD computer will have a heart attack over this radical change, would MAF handle this better? Reason I ask is because I made another post in the TPi section of going from SD to MAF for mod acceptability and would wonder if this would be safe, or would it just be a simple chip burn for the SD? I don't have a chip burner nor the access to one. And I don't have time to have one sent to me and back and forth if it doesn't work you know.
Thanks guys!!
-Kevin
Old Mar 27, 2005 | 09:26 PM
Red WS6 Ram Air's Avatar
Car: 90 ws6 formula
Engine: 305 tpi
Transmission: t-5
i heard that lt1 heads don't work properly, plus their a reverse flow cooling setup. You can read up on www.lt1intake.com
Old Mar 28, 2005 | 12:15 PM
sellmanb's Avatar
Car: '86 Berlinetta
you'll need a little more suspension work for that.
what's your tranny going to be? You'll need to beef it up in order to hold up to a 12/13 second car.
What about the rear diff. ?
To get into the 12/13's you may want to go with a lil more cam. the CC305, or 306 even if you want to go a little more radical... both of these cams are streetable still. If you choose your stall converter at the right speed, then it would be perfectly streetable.
69GTOby
Apr 18, 2016 02:34 PM
codeysabatini
Nov 10, 2015 04:07 PM
sreZ28
Oct 22, 2015 08:21 AM
customblackbird
Oct 1, 2015 04:30 PM
Liveaction
Sep 17, 2015 06:29 PM
