Idling Issues
Old Mar 28, 2005 | 10:44 AM
trueburton's Avatar
Car: '88 Red Trans Am w/ T-tops
Idling Issues
My car has an idling problem. It will idle up to about 1300 and stay there for like 3 secs and then gradualy drop to about 800 and stays there for about 3 secs and then goes back up to 1300. What could cause this? I have checked Vac leaks and replaced the IAC and ajusted the TPS and I can't figure it out. any ideas?
Old Mar 28, 2005 | 12:20 PM
sellmanb's Avatar
Car: '86 Berlinetta
Definetly sounds like a vacuum leak of some sort.
When you checked for vacuum leaks, did you spray WD40 or anything like that all around the engine bay to find the leak?
Old Mar 28, 2005 | 01:23 PM
blue86iroc's Avatar
Car: 1986 IROC-Z
Try doing a search and include the word surging in the search terms. These cars tend to have issues with a surging idle at times, especially with TPI.
Old Mar 28, 2005 | 04:01 PM
trueburton's Avatar
Yes I've tried spraying brake cleaner and can't come up with anything. I just repplaced intake gaskets, runner, and plenum gaskets and TB gaskets so that should be sealed off. I have also replaced many vac lines that looked or felt brittle or just had loose connections. I haven't tried searching for surging idle so i'll give that a try. Please keep the suggestions coming. Thanks
specialized
Jun 18, 2022 09:26 AM
Street Lethal
Apr 30, 2019 12:14 PM
bamaboy0323
Sep 3, 2015 06:07 AM
mike_c
Aug 27, 2015 04:32 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
