EST vs HEI
Old Mar 28, 2005 | 10:41 PM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
EST vs HEI
Is there any problems with droping in a vac. adv. HEI in place of the computer controled EST dist? Car's spec's are in my sig.
Old Mar 29, 2005 | 12:17 AM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
well you didn't post your sig
why do you want to replace the conventional way of controlling your car via computer, especially when the provisions are already there? If your car isn't running to par, then fixing something else isn't going to solve your problem.
Old Mar 29, 2005 | 12:19 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Your stock computer controlled distributor is an HEI, just a different type. The only reason you'd want to put in a mechanical advance distributor would be if you were converting to a non-computer controlled carb.
Old Mar 29, 2005 | 10:55 AM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Why would I want to change the coventional way to control my car via computer? Without a data log system, scan tool, and a way to burn chip's, the computer's peramater's are about this wide / / . I consider mine as "the little box of retard's" under the dash! Think of your motor as your child, and the computer as being a live-in nanny. I tired of living under the bitch's rules!
Old Mar 29, 2005 | 11:19 AM
ede's Avatar
ede
i was going to say something about still living in the 60s but from your profile i see you grew up with carbs like me. actually i grew up with FI in the 60s on a gas class chevy the old man raced. i thought all cars had hilborn injection since the race car was the only one i ever seen the engine in.
Old Mar 31, 2005 | 07:33 AM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Yup! What ever happened to ROOTS?
Old Mar 31, 2005 | 12:36 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
I personally like the computer. Ive made the computer into a machine that does all the hard work for me so I can assume my usual role of 'loose nut behind the wheel'.
You dont have to datalog to set the timing. Come to think of it, theres not much in the datalogs that would help you. Knock will only tell you if you have too much timing, and even the knock sensor isnt a good indicator of anything at times.
You can just plug in what you would normally run with a vac advance dist. into the timing tables and get the same effect. I have one single large timing table with nearly 300 individual points so tuning every point is just way out of the question. I just plugged in the type of timing youd get with a mechanical dist. and just left it. Works fine.
Its possible to get the computer to work with a vac adv. dist. The problem is that with the stock speed density your fueling will be off so youd have to go back and retune it to get the best performance.
L98GTA87
Oct 19, 2015 10:43 PM
skinny z
Oct 5, 2015 06:23 PM
Justins86bird
Sep 27, 2015 09:43 AM
Damon
Sep 26, 2015 04:29 PM
pacoelrapido
Sep 11, 2015 02:41 PM
