How Big Of Injectors?
Old Mar 31, 2005 | 08:29 AM
klumb15's Avatar
I gotta buy my injectors and fuel rails pretty quick, and I need to know how big of injectors i should get...i'm running the XE276HR cam, L98 alum Heads, HSR intake, 58mm TB, Full exhaust, custom computer programming, and a few other things to bring my motor up to about 350-400 HP....i was thinking maybe just running like stock LS1 injectors because I believe they are 28#er's, am i right? i was thinking like 28 or 30 pound injectors would be sufficiant, what do you guys think? also, are all injectors the same? will i have to worry about differenent injectors not fitting with the holley fuel rails??? A guy has a set of used 36 # holley's for sale for 200-250 i believe...but 36 is too big I think..what do you guys think, how big should i go??
Old Mar 31, 2005 | 09:38 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Ford motor sport 24 lbs or the SLP's 25 lb/hr would work fine.
Old Mar 31, 2005 | 09:59 AM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
http://www.iroczone.com/calcs/injectorsize.htm
Old Mar 31, 2005 | 08:26 PM
klumb15's Avatar
so 36 # injectors are just wasting money then...because I know you can get new ones for under 200, i thought 250 for used injectors was kind of high...that calculator came out to be about 29#, i don't know if i did it right tho...i was told by the guy that is doing my chip that i could get away with the stock 22's if i wanted too, so i'm thinking i don't have to go much bigger than that...i'm thinking in the 25-30 # range should be sufficient....where is some good places to get injectors at a decent price, anybody know??
Old Mar 31, 2005 | 08:33 PM
pasky's Avatar
Get some ford SVO 30# from summit. Only other way to get a better price is to order from ebay or find some on forums.
Old Mar 31, 2005 | 08:42 PM
klumb15's Avatar
so those fit and work fine with the stock wiring harness and holley fuel rails right??
Old Mar 31, 2005 | 08:51 PM
pasky's Avatar
I know they'll work with a stock application (TPI, LT1), not sure on the holley fuel rail. But wiring harness yes.
Bubbajones_ya
Jul 6, 2024 08:32 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
Nick McCardle
Sep 10, 2015 08:36 PM
