Will these valve springs work?
Old Mar 31, 2005 | 08:58 AM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
I found these valve springs on ebay, will they work? They will be going on a 416 head with a cam with lift 445/465.
Old Mar 31, 2005 | 08:59 AM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
oops, heres the link:
http://cgi.ebay.com/ebaymotors/ws/eB...sPageName=WDVW
Old Mar 31, 2005 | 09:02 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Note the p/n starts with "RV". That should tell you something.
You should go for something better.
Old Mar 31, 2005 | 09:04 AM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
So what does that mean?
Old Mar 31, 2005 | 09:10 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
They are stock replacement springs.
You're using an aftermarket cam. No stock springs are adequate for any aftermarket cam.
They are only "good to .550" lift" if set up .050" taller than stcok, and 30 lbs lighter on the seat (valve float will occur that much easier). They coil bind at .550" lift when installed correctly. That means their true "max lift" is about .490" when installed correctly... basically about the same as any other 1.25" spring.
I would recommend gettting some real valve springs instead of stock ones. That's not the place to try to shave a couple of pennies; which is about all you're going to shave. Not worth it.
Old Mar 31, 2005 | 09:25 AM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
ok, i see, so what should i look for when i buy springs?
Old Mar 31, 2005 | 09:30 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Whatever the mfr of your cam says you should use.
customblackbird
Aug 15, 2021 10:16 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
89mulletbird
Aug 12, 2015 07:08 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
