question about 87 TPI engines (general)
Car: 1984 Camaro on steroids/ 1987 iroc-z28 5 speed.
Engine: 383 nitrous motor / poindexter 305
Transmission: Th350
I am about 80% sure no. I think the newer ones have 168 tooth flywheels and the older ones have 153 tooth flywheels.
Car: '86 Berlinetta
Mine does lol. Just as long as the bolt holes line up, then you can use it. There's no such thing as a "2 piece rear main seal starter" or "1 piece rear main seal starter". You WILL need to swap flexplate/flywheels to the appropriate tooth count per the starter (on ours I believe it is 153
But yeah, just as long as your block has the correct starter bolt holes... And if it doesnt, you can always take the block to a machine shop and have them do it, it's no big deal for them, and they charge less than 50 typically... which is less than you'd be paying for a new starter if one would fit that bolt pattern (there is none for our cars btw, no if's and or buts... there's not a single one)
) .But yeah, just as long as your block has the correct starter bolt holes... And if it doesnt, you can always take the block to a machine shop and have them do it, it's no big deal for them, and they charge less than 50 typically... which is less than you'd be paying for a new starter if one would fit that bolt pattern (there is none for our cars btw, no if's and or buts... there's not a single one)
The_Phoenix
Sep 3, 2015 10:56 PM
R3500
Aug 17, 2015 12:16 PM
Sanjay
Aug 12, 2015 03:41 PM
