how to remove axle shafts?
Old Apr 1, 2005 | 01:45 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
i need to remove the axle shafts i guess they are called in my 10 bolt, so i can replace my caliper brackets. i pulled the cover off, and i think i need to pull those main bearing caps off it looks like. what else do i need to do to pull these puppies off? thanks.
Old Apr 1, 2005 | 05:43 AM
ede's Avatar
ede
leave the bearing caps alone. remove the cross bolt, 5/16 hex, then the big pin, push the axles in and remove the c clips then remove the axles. replace the pin and bolt untill you reinstall the axles, don't spin the carrier with the pin out. bet if you did a search on the correct forum first you'd found this along info with a pic
Old Apr 1, 2005 | 11:18 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
ya if i knew what i was searching for, dont know the correct terms so whatever. but thanks. only thing is, what is the crossbolt?
Old Apr 1, 2005 | 12:32 PM
ede's Avatar
ede
5/16 hex on the right side of the carrier, holds the big pin in place, goes from right to left
Old Apr 6, 2005 | 07:27 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
thanks ed, i got my new brackets today, im assuming they will bolt up so the calipers stay on the same side of the axle.
one last question, can i go ahead and bolt these new caliper brackets on, or do i need to also bolt something like the dust shield using the same bolts?
hope you know what i mean. on my current 9bolt axle i got a caliper bracket and what looks like a dust shield, do they share the same bolts. and do i need to use these dust shields on my new 10 bolt, or can i just bolt on my brackets and slide the half shafts back in.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Stryker412
Sep 7, 2015 09:11 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
tonys91rs
Sep 2, 2015 07:07 PM
greenyone
Sep 2, 2015 03:39 PM
