Using a nickel in the fuel regulator
I currently have my plenum off right now, and was thinking of using the nickel trick to bump up the pressure. How much will it bump it up to? Currently it will max out at 41psi.
Rob
'86 TA 305 TPI
Gutted MAF, Ported Plenum
TB Bypass, Home made Cold Air Intake,
Edelbrock T.E.S.
Rob
'86 TA 305 TPI
Edelbrock T.E.S.
try it and find out
87 z28 bowtie aluminum 420small block dry sump crower lt. wt. knife edged crank oliver lt wt rods brodix track 1's super ram intake slp 1 3/4 headers accel dfi art carr 700 r4 3.42 gears ssm sub frame/ladder bars.....other parts on the way ,soon to be finished!! couple more weeks!!!
Car: 86 T/A
Engine: 5.0 TPI
Rob you're actually not sitting bad at 41 unless you're just wanting to experiment. Vader submitted an article to my site for building your own AFPR. Might give you a little more flexibility.
<A HREF="http://www.gmtips.com/3rd-degree/dox/tips/afpr/afpr.htm">Build Your Own AFPR for $1.00</A>
... however it will cost 95 cents more!
Car: 86 T/A
Engine: 5.0 TPI
I think you might have hit it right on the money. With my AFPR I set it to 46/47. But you're right it would depend on your mods. Mine is basically stock, just ported and a hotter coil.
I couldn't wait any longer, and I put everything back together today. The car runs great!!! Now I can't say I increased my hp by 10 ponies or such, but she feels much smoother and faster in the rpms.
9192camaro
16
Feb 3, 2019 12:21 AM
ambainb
Apr 25, 2016 09:21 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
