got it
Old Apr 2, 2005 | 01:37 PM
MustangMuncher's Avatar
Car: 89 Camaro
Engine: 355
Transmission: Coan rebuilt TH700R-4
got it
Ok I figured it out. For those of you that have TBI, take off the fuel pump relay located on the firewall driver side. Take the tan and white wire or known as "A" on the 5 wire harness. Run an ignition wire to that terminal and throw the relay away. When you turn on the key from now on this will turn the pump on.
Old Apr 2, 2005 | 02:10 PM
kevinc's Avatar
Car: 1982 Z28
Re: got it
And when you wreck it, the pump will keep right on running until you turn the key off...if you're able to...
Future Darwin award pending.
Old Apr 2, 2005 | 02:39 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
relays are $7. that's cheap insurance against a car fire.
Old Apr 2, 2005 | 02:53 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
The relay is there to handle the current that the pump draws...your wiring may or may not be sufficient to handle sustained pump running.
Why take a chance?
Old Apr 2, 2005 | 03:20 PM
bubbz89's Avatar
Car: 1990 RS
Transmission: TH-350
