screwed up my car!!!!!
Old Jul 27, 2001 | 12:52 PM
Matt's Avatar
ok installed new carb and dist. checked all the lines both vacuum and electrical. everyting is connected. installed dist with the balancer at 0* and teh rotor pionted at the #1 cylender. car turns over but wont start. any ideas on what it could be? tired of driving my honda need to go fast. By the way i have a 84 305. the new carb(edelbrock 1406) and dist(accel 9107) are non computer controlled.
Old Jul 27, 2001 | 12:55 PM
Matt's Avatar
correction it doesnt turn over but cranks. sounds like its trying to start but just doesnt.
Old Jul 27, 2001 | 02:19 PM
ATOMonkey's Avatar
How long did you crank? The bowls have to fill, after that I'd check for power to the spark and then make sure the timing is right. Maybe have a friend use a timing light while the engine is cranking to make sure about timing.
Old Jul 27, 2001 | 02:36 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
My guess is the distributor is installed a tooth off, or the plug wire routing is incorrect.
1992 Trans Am
May 10, 2023 07:19 PM
Reddeath210
Oct 6, 2015 08:20 AM
camaro71633
Sep 1, 2015 10:24 AM
Linson
Aug 21, 2015 02:12 PM
blacksunshine'91
Interior Parts Wanted
Aug 10, 2015 12:04 AM
