"Blowing out" the heater core...
Old Apr 3, 2005 | 07:30 PM
Crusin' 1980's's Avatar
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
Has anyone ever had their heater core blown out with an Air hose to "unclog" the buildup and to allow more heat through the vents? My brother had it done and he said it helped him get about 80 % of his heat back? Has anyone else had any experience with this? (I've noticed that my heat isn't that goog and i was considering this)
Old Apr 3, 2005 | 09:14 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
If you have buildup in your heater core, odds are that your interior cabin heating problem is the least of your worries. If you've got sediment clogging your coolant lines, I advise you to get a coolant flush immediately.
Old Apr 4, 2005 | 05:25 AM
icarus402001's Avatar
I think he means crap cleaned out from between the vanes not thru the water passages. That should make a big difference. It's a routine maintenance procedure in HVAC.
Old Apr 4, 2005 | 05:27 AM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Old Apr 5, 2005 | 04:50 AM
Hellraiser's Avatar
definately
Yeah, i do this sort of service on chevy blazers and other vehicles where heater core replacement is prohibitive... definately worth your time.
Fanatic1074
Oct 2, 2015 03:47 PM
Formula8r89
Sep 22, 2015 04:24 PM
