non third gen question
Old Jul 28, 2001 | 08:06 PM
thefastest's Avatar
I have a 1989 chystler new yorker. when I go to turn on the car the lights dim out completely and the car will not turn on. I thought that it was the battery so I went and put in the battery of my camaro(this battery was charged to the max, 1000 cold cranking amps) and the same thing happened. the jumper wires that I used to connect the battey were very hot. what could be the problem. I know its not the ecu because I already replaced it. what could be doing this
Old Jul 28, 2001 | 08:38 PM
witchdr's Avatar
Call a Chrysler dealer. That's what I'd do.
Old Jul 28, 2001 | 10:47 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I'll take a WAG at it, could be the powersteering belt slipping along with the ALT belt and dimming the lights?
Old Jul 28, 2001 | 11:09 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
For starters, check all your connections and grounds...keep in mind, just because they look good, doesn't mean they are.
The starter could be drawing too much amperage.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
[This message has been edited by Engineboy (edited July 28, 2001).]
Frozer!!!
Jan 19, 2024 04:55 PM
69 Six Pack
Oct 5, 2015 07:51 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
