Could this cost me 150 bucks?
Car: 1990 Camaro RS
Engine: 3.1 V6
Transmission: TH700?
My EGR seems to be leaking but not from the adapter gasket. Is there perhaps a gasket in between the solenoid and the base that may save me $150.00 I havent really had a chance to look at closely but it looks like it comes apart. If it were leaking from the adapter, i could simply replace the gasket, but this doesnt look good.
Car: 1990 Camaro RS
Engine: 3.1 V6
Missing screw
Cool, i had no idea it may be that simple, unless it is broken off. I recently purchased the car so Im not too sure of what might have happened. I havent gotten my manual yet so I appreciate the pic. I guess I'll be yanking that off to see if theres a bolt down there. If so I'll tap it out. I can only imagine how long it been like that, I purchased it about a month ago, so who knows the extent of the damage. I must say, I love my F-body but uits starting to nickle and dime me to death
Thanks again though!
Car: 3
Engine: inboard
Transmission: underfloor
I hate to tell you, but I searched and searched, and the baseplate gasket is not sold separately anywhere. The 3.1 was only used in this application from '90-'92, the earlier 2.8's used an entirely different EGR system.
I drilled out the broken screws, tapped the holes in the lower part to 10/32, and made a gasket of high temp thick paper. It worked for a little while, until I found a near new EGR on a car in the junkyard.
A complete new EGR for these cars is nearly $200.00.
Car: 1990 Camaro RS
Engine: 3.1 V6
Car: 1990 Camaro RS
Engine: 3.1 V6
Ok, all back to normal and actually two of the bolts had broke. On ewas still in place though so it didnt look broke. Once I tapped them out it was simply a matter of fiing new bolts (hint: 4-.7 is the size) Now the only question will be how much carbon build up has occurred.
no green
Jan 9, 2016 09:22 PM
darwinprice
17
Oct 11, 2015 11:51 PM
Damon
Sep 26, 2015 04:29 PM
