MSD broke before i could use it
Old Jul 29, 2001 | 03:20 PM
nativ's Avatar
I just instaled new plugs, wires, cap, rotor and coil. Cap, rotor and coil are msd. When i put the coil wire on the coil it felt fine then i went to put other end on cap the tip on the coil broke off. this is a gm/blaster coil. it lookes like amanufacturing defect becouse the middle of tip is hollow. has anyone had a problem with msd products before. could this be a bad lot.returned it today 7/30 for new one will post how it works later.
[This message has been edited by nativ (edited July 30, 2001).]
Old Jul 29, 2001 | 05:58 PM
rezinn's Avatar
Damn! How far away is your coil mounted? I have plenty of slack with mine, I don't think I could break it.. Anyway, just return it to where you bought it and get a new one.
Old Jul 29, 2001 | 06:35 PM
nativ's Avatar
its right next to dist,. i was putting the coil wire on the cap with a loop in the wire and it just fell off the coil. i did'nt put that much force on the coil either.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
bjpotter
Oct 4, 2015 07:48 PM
sjorgens
Oct 1, 2015 07:54 PM
meeklay812
Oct 1, 2015 03:46 PM
