harmonic balancer troubles
Old Jul 29, 2001 | 07:49 PM
StevenV's Avatar
OK, well, I got my 82 Firebird a couple months ago with a blown engine, so I got a new 305 in there and it ran fine for around a month or so, then about a week ago I started to hear a rattle so I jacked it up and saw the harmonic balancer had slid back and was rubbing against another piece of the engine. It slid rather easily to its normal position, and it still does slide easily.. why? and how can I fix it?
Old Jul 29, 2001 | 08:00 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You need a new one. The blob of spooge that holds the outer ring to the inner part has failed completely. You can get them in the Pioneer brand from machine shops and such, or from Summit, or even the dealer. You can "rent" the tool to remove and install it at AutoZone or Kragen or many other parts places.
ICON Motorsports
ede's Avatar
ede
replace it and make sure it has a key in the crank and the crank isn't messed up
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Jul 29, 2001 | 08:27 PM
StevenV's Avatar
how much will it all cost and is it too much to do in my own garage? thanks for the quick help
Old Jul 29, 2001 | 08:51 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
<font face="Verdana, Arial" size="2">Originally posted by StevenV:
how much will it all cost and is it too much to do in my own garage? thanks for the quick help</font>
I beleive the small "305" ballancer is around 60/70$ new, or you could probably get a used one real cheap but you might end up in the same situation a few months later.
SSC
Old Jul 29, 2001 | 09:13 PM
StevenV's Avatar
thanks for all the info and the quick responses..
mrbird
Oct 20, 2015 03:43 AM
monte87cortez
Sep 26, 2015 08:10 PM
Lmancha96
Sep 25, 2015 08:11 PM
roysatikas
Sep 22, 2015 08:15 PM
Magman
Sep 13, 2015 12:14 AM
