removing the air pump
Old Jul 29, 2001 | 03:09 AM
silver89Rs's Avatar
will taking off the air pump on my car mess with the o2 sensor reading?
89 Rs camaro
305 tbi
3in flowmaster muffler
manderal bent pipe
no cat
Old Jul 29, 2001 | 09:22 AM
smurfmobile's Avatar
no
Old Jul 29, 2001 | 09:56 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
NO.
FREE CARFAX Record Check
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
Old Jul 29, 2001 | 10:47 PM
silver89Rs's Avatar
ok then what do i use to block off the air injection holes in the manifolds? or can i just bend the tubes over and pinch them?
89 Rs camaro
305 tbi
manderal bent pipe
no cat
Old Jul 30, 2001 | 12:03 AM
ArnoldBraker's Avatar
<font face="Verdana, Arial" size="2">Originally posted by silver89Rs:
</font>
IF you do that you'll probably create exhaust leaks. I unscrewd them from the manifold and took one of the old fitting to the hardware store. I used that to find a brass plug which would fit in the manifold hole. I can't remember the exact size but I *think* it was 1/2.
RazorN8
Jan 7, 2022 11:44 AM
Vintageracer
Jan 10, 2020 05:33 PM
backtothe80s
Sep 5, 2015 12:39 AM
mcquigg
Aug 13, 2015 02:26 PM
3rdgenparts
Aug 8, 2015 07:09 PM
