Fuel pressure too high or too low?
Old Jul 29, 2001 | 04:44 PM
Enkil's Avatar
Fiddling around with my fuel pressure, my car runs worse now.. Unfortunately I don't have a fuel pressure gauge to tell where I'm at exactly. I can't tell if it's too high or too low.
There's a noticed loss of power all throughout the RPM's, and when I go from a stop part-throttle it'll go, stop, then go again.. It's not quite a bog, and it doesn't sound like it's going to die. It's as if I just took my foot off the gas for a second.
Any ideas? I know it's rather vague...
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Old Jul 29, 2001 | 05:52 PM
rezinn's Avatar
As my AFPR instructions said, "add pressure in 2psi increments until you no longer notice a gain in power at high rpms, then decrease pressure in 2psi increments until you feel a loss, raise pressure by 2psi."
So try raising pressure until you feel the power come back, and when you can't feel it anymore lower it a bit.
Also, since your car kind of bogs for a second before you accelerate, you may be (or have been)running way rich and have gotten your spark plugs dirtied. You might want to pull them and see if they are dirty and clean them off.
Old Jul 29, 2001 | 07:27 PM
aquila's Avatar
running the adjuster screw in makes it richer (higher pressure) and out makes it leaner ( lower pressure)
Old Jul 29, 2001 | 07:39 PM
Omar's Avatar
I know you know this already, but you REALLY need to buy or borrow a gauge to see where you are at.
1989 IROC-Z 5.7L
NOS 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
Old Jul 29, 2001 | 09:47 PM
iroc5speed's Avatar
aquila those adjuster screws are on carbs not throttle bodies
[This message has been edited by iroc5speed (edited July 29, 2001).]
Old Jul 30, 2001 | 01:38 AM
Enkil's Avatar
Actually there is an adjusting screw for the fuel pressure on TBI's. I just needed your dremel to get to it. ehheh
89 iroc-z 305 tbi
92camaroJoe
Jul 29, 2023 07:57 PM
Fronzizzle
Aug 19, 2015 01:36 PM
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
