what's a good "keyed" source for fuel pump/distributor ?
Old Jul 30, 2001 | 07:41 AM
smurfmobile's Avatar
I'm wondering where should I hook up both of those ?
obviously the electric fuel pump needs to be "key on" source only , and I'm not sure about the distributor (vaccum advance).
for the distributor I would like to use the original wireing , but of course the plugs don't "match" so I would have to splice it , but my LG4 dis. had two pig tails with I think 9 wires , so I have no clue which one I should use... my haynes manual is missing the "electrical chart" page , bastard misprinted those few pages and they are unreadable
so what should I use ?
I would like to hook up both to the same source so in case they both stop working then I know where to go to fix it... plus if one works and the other one doesn't I'll know that it's not a power issue....
soo...
any recommendations for a good "key on" source only ?
Old Jul 30, 2001 | 09:17 AM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
If you look on your fuse panel you should have 2 open plugs for accessories that you can use for "key on". Just use spade terminal to connect to the box.
As for the distributor you shouldn't have to splice anything. When I swapped my distrib for a vaccum I had to change nothing just plug the plugs into the coilsockets. the 4-5 wire pigtail that went to the CC you just don't use anymore.
1985 ASCD Ram Air Trans Am
Readers Ride at https://www.thirdgen.org/rides/index...ew&rideid=1067
-=ICON Motorsports=-
" I get drunk, I race cars and I fondle women. But... I have weekends off and I am my own boss"
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
bellez77
Sep 5, 2015 08:39 PM
Jae992
Aug 27, 2015 09:07 AM
Kaweh
Aug 9, 2015 02:54 PM
