All big CI SBC guys inside
Old Apr 7, 2005 | 02:19 PM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
I see a couple of people on here have been talking about their big cubic inch small blocks they have, like 434s and whatnot. What kind of block are you guys using for these buildups? Im assuming it has to be like a dart or world products casting unless you guys know some way to take a factory block out to an insane bore. So what are you guy packing under the hood?
Old Apr 7, 2005 | 02:46 PM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: All big CI SBC guys inside
I am using a 400 block. Got it out of my 71 Chevy P-up. You can't bore them out more than .060...is that what you consider insane? Mine was bored .030 and is now a 406.
Old Apr 7, 2005 | 02:59 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Like I posted in repsonse to the other instance today of the same question, the biggest one I've dealt with personally is a 434.
It was a stock 400 block (509 casting IIRC), 4" stroke crank (Eagle in that case), Eagle H-beam 6" rods, .030" overbore. Used a custom cam, basically it was just a XR282HR on a small base circle.
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
Street Lethal
Aug 14, 2015 08:25 PM
sreZ28
Aug 14, 2015 07:48 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
