Car showing 3 different codes
Old Apr 7, 2005 | 08:16 PM
90tagta's Avatar
Car: 1990 Trans Am GTA
Transmission: 5-Speed
As stated above my GTA is pulling three different codes. 42,43, and 46 What should i do to begin with to try and fix these problems.
Old Apr 9, 2005 | 06:19 AM
Vader's Avatar
You might want to start by verifying the connection for EST bypass, check the knock sensor and its connection, and clean your ignition key/lock cylinder contacts.
Old Apr 9, 2005 | 09:29 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Sure to check the above, then disconnect the battery for a minute and try again. Might try unplugging the four wire connector on the back on the distributor and reconnecting to clean terminals. Some more info:
http://www.troublecodes.net/articles...ndrstd42.shtml
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
mizz0313
Aug 12, 2015 06:45 AM
apie2546
Aug 10, 2015 05:43 PM
ryanz281988
Members Camaros
Aug 8, 2015 06:45 AM
