Do I have rod knock?
Old Apr 8, 2005 | 02:12 AM
v8nate92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 L03
Transmission: Borg-Warner WC T-5
I have read the posts about rod knock, but I am not sure exactly what is wrong with my 305. It has had this ever since I bought it. I thought at first it was an exhaust leak, but I had my exhaust system checked and they said it was "perfect."
Here's the deal:
My car makes ticking noises and slight knocking noises. When the car is cold, they are hard to hear, but as soon as the engine gets up to operating temp I can hear them easy. The first knock is more of a puff, puff, puff heard fairly loud at idle coming from the driver's side of the engine. I thought this one was the exhaust leak, but its not, maybe piston slap? I don't know. The other is a ticking/knocking noise during accellaration. It too seems to be coming from the rear passenger side of the engine. Does this sound like rod knock to you?
Old Apr 8, 2005 | 07:05 PM
v8nate92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 L03
Ok...
So no one can help?
Old Apr 8, 2005 | 07:12 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Being a victim of rod knock myself (https://www.thirdgen.org/techbb2/sho...hreadid=289589)
I'd have to say no ticking at cold start up would indicate it isn't. It would be constant and get louder as the rpm's increase and be consistent with the rpms, in my case I could actually feel the damn vibrations in my clutch pedal and the car would shake.
Your situation sounds like an exhaust leak, valves need adjusting or stuck lifter.
Old Apr 10, 2005 | 11:38 AM
MaxxMitchell's Avatar
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
Does your car have the Smog pump or AIR system?, i know the AIR system with a leak will sound like a ticking, but very fast.
RedLeader289
May 28, 2019 01:47 PM
Ed1LE
Sep 30, 2018 09:14 AM
bigjay89gta
Oct 15, 2015 08:04 AM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
