Hesitation, loss of power
Old Jul 31, 2001 | 01:37 PM
Eric's Avatar
Car: 87 GTA
I have a nasty little hesitation when I accelerate normally - it bogs then jumps. If I accelerate very gently, or real hard there is no hesitation. I also have noticed lately that somtimesif I accelerate normally for a second or two then get on it, it dies right off (not stalled, just no power at all) for a sceond with what sounds like a backfire, then if I let off the gas and back on it is fine. On top of this I have noticed that sometimes when starting the car it starts to rev as normal (higher revs then down to idle speed) but then sputters and idles rough for a second then idles up again.
The plugs look good (I pulled several randomly (since they are such a bitch to get at)), the plugs wires seem good (newer Accel), the cap and rotor look fine. The injectors have been rebuilt last summer. I don't appear to have any vacuum leaks (did the standard carb spray test) but I can't be 100% certain. There are NO CODES.
Any help would be greatly appreciated!!
Eric
87 GTA 350 TPI, 700R4,
K & N, Accel cap/rotor/wires, SLP airfoil, ported plenum
Old Jul 31, 2001 | 02:04 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
More than likely your TPS sensor has a dead spot in it.
Kat
theshackle
Sep 17, 2020 08:26 AM
formula_novice
Sep 5, 2015 03:58 AM
Warlocksirix
Aug 29, 2015 11:36 AM
sailtexas186548
Aug 24, 2015 10:11 PM
db057
Aug 22, 2015 08:17 PM
