Emissions...
Old Jul 31, 2001 | 12:38 PM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
Emissions...
Well I'll soon be moving to CT and it seems they have the beloved emissions laws there. I'm not sure yet whether they do visual checks, but thought I'd post to get opinions on whether I'll be ok at the sniffer. I have a 3" pipe instead of a cat, stock manifolds with 3" exhaust after that, manifolds plugged and air pump removed. I have the egr and charcoal stuff intact. The only thing that prevents me from just reinstalling all the stuff (except the cat) is that I don't trust the steel air lines and the old rusty fittings on them from before. I know I should run a hot thermo and let it warm up awhile before I go for testing, but does anyone else have any tips? If they do a visual I'll be pi$$ed that I have to fork over so much more cash to get the a.i.r. equipped headers....
[This message has been edited by I ROCK (edited July 31, 2001).]
Old Jul 31, 2001 | 02:47 PM
ATOMonkey's Avatar
If you don't have a cat you're screwed. It's the only thing that lowers NOx and CO. Well, that's not exactly true EGR lowers NOx about 10-20% depending on what day it is and how much you can run. You can lean out the carb to get rid of HC, but no matter what you do to the engine with no cats you will fail the CO. The steel air lines that go to the cat add O2 to make the cat more efficient.
'89 Red Formula 350- 350 .060 over forged pistons 232* @ .020 cam Performer RPM Holley 750 DP Vortec 1.94 1.50 Accel Coil and dist. Hedman shorty headers Dual Exhaust w/ cutouts 1LE WS6 suspension, wheels, and brakes, 9 Bolt 3.27 Posi Edelbrock LCA's & Track bar subframe connectors 700R4 A&A snorkel scoop Eclipse Head Unit Delco Bose Speakers 2 12" Pioneer subs w/ 400 watt/chanel amp
Bo Sandoval
May 2, 2013 10:06 PM
GOTCHEVY
17
Sep 16, 2011 11:42 AM
newZman
Jun 5, 2011 05:14 PM
ViciousZ
Southern California Area
Jun 8, 2002 06:48 PM
