Ajustable Push Rod Length Checker
Old Apr 10, 2005 | 03:05 PM
JesasaurusRex's Avatar
Doing my finishing shopping for my 400. I need to know which length adjustable push rod length checker i should get because they have some from like 6.5-7.5" and some from 7.5-8.5" etc etc. I wont wanna buy 2 of em . Anywayz solid roller cam, AFR 220 heads, 9.025" deck, .039" head gasket. What do you guys guess the pushrod length would be so i can get an ajustable pushrod in that area. Thanks fellas. Appreciate it.
Old Apr 10, 2005 | 03:21 PM
k im guessing the 6.8-7.8 pushrod length checker is a good place to start. Also do you guys know if the comp cam ajustable push rod is 5/16" or 3/8"?
Old Apr 10, 2005 | 04:33 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
What size rockers are you using? I have the competition cams adjustable pushrod (summit #CCA-7901-1)The size is 7.5 to 8.7. This is what I used for my vortec 350 with LT4 hot cam and 1.6 roller rockers. Yours for 12.00 shipped.
Old Apr 11, 2005 | 12:34 AM
1.6 7/16 stud. I just want to be sure the pushrods i buy is inbetween that 7.5-8.7" length. If not its kind of useless ya know. So im trying to get an estimated pushrod length first.
Old Apr 11, 2005 | 02:27 AM
Anybody with a solid roller cam and knows the length of their pushrod can chime in here
Old Apr 11, 2005 | 08:15 PM
Bump
Old Apr 11, 2005 | 08:33 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
I'd call AFR and ask them. Reason is this was one of the big problems TFS ran into with their G1 heads. Some of the lenght checkers did not work properly with their casting. Main reason I beleive was the valve configuration, however, I never really looked into it to verify if that was the only reason or if there were others. I'm a bit **** when putting together stuff.
Old Apr 11, 2005 | 09:15 PM
Ya i should would be the easiest way to go. Thanks for the advice i should have thought about it myself
Old Apr 12, 2005 | 01:37 AM
TheMysticWizard's Avatar
Car: 1987 Firebird Trans AM
Engine: 383 TPI...very soon
Transmission: TH700R4
I'm pretty sure hydraulic roller pushrods are 7.200
I don't know about solid roller. I need to get a checking pushrod myself... but I am looking for like 6.800 to 7.500 or somewhere around there.
Old Apr 12, 2005 | 09:25 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Solid roller ones are all over the place. There's not just one "standard" length, like there is with stock hyd rollers.
SBC push rods are 5/16", usually.
The tool I use is the Comp 7702.
RedLeader289
May 28, 2019 01:47 PM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
loud91rs
Oct 5, 2015 10:05 PM
skinny z
Oct 5, 2015 06:23 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
