Car idles high and misses
Old Aug 1, 2001 | 10:50 PM
NCZ28's Avatar
I have an 84 Z with an LG4, stock Q-jet. The other day it just started idling at 1000-1500 RPM. It will not idle down. I backed the idle screw out so far that it isn't touching the throttle linkage. The idle seems to go up as the engine gets warmer. It also started skipping at the same time. It only seems to do it at idle or when I let off the gas while driving. I thought it may be a vacuum leak, but I have looked everywhere and I can't find one. Any help would be appreciated.
Old Aug 2, 2001 | 10:53 AM
topduarte's Avatar
Car: 92 Heritage Camaro Z28
Transmission: auto
Axle/Gears: 3.23 Limited Slip
My car was running high for awhile. Mine is TPI but I checked the cables and put some moly grease and worked it in and out.
It could be a frayed cable that is getting caught up or even something getting caught in the florrboard (like loose carpet, floormat, etc).
Hope this helps!!!
Manny
92 Bright Red z28, 350, 47k miles, pw, pl, power mirrors, power drivers seat, rear defroster, limited slip performance axle, 4 wheel discs, red leather interior and the Heritage Package!!
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
Exxon Limited
Aug 9, 2015 08:13 PM
