could i run 400 or so torque on my stock rear end?
Old Aug 2, 2001 | 01:59 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
do any of you that hvae built up engines have your stock rear end?
cuz my bro says i should go with a 12 bolt.....but i dont really feel like spendin a lot of money on my rear end.....i was just wondering if i could only build it up some and it would b ok???
84TA T-tops L-69 305HO TH-700R4 stock 190hp and 240 ft-lbs.
new best E.T. (dont laugh) 15.986 @84.93mph
old best E.T 15.997@86.04
http://www.geocities.com/K_towngangsta
Old Aug 2, 2001 | 05:10 PM
ede's Avatar
ede
i've run more hp than 400 with a 7.5 10 bolt with no problems. a lot depends on how hard it hooks up. some people have broke 10 bolts with stock engines.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Aug 2, 2001 | 05:20 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
well i doubt i will get much over 400 torque IF i do at all
but what would you suggest i do to my rear end to make it stronger.....right now its makeing a whineing noise so i dont know if its ready to go out or not....but im pretty sure im gonna have to build it up some b4 i get the 355
Old Aug 2, 2001 | 05:26 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I've run over 400 HP and way more than 400 ft-lbs of torque through my 10-bolt. Like the T-5, the one thing it will tolerate the least is shock; don't dump the clutch or speed-shift, and it will put up with a surprising amount of abuse.
What's wrong with your L69? That car should do about a 15.3 or 15.4. It's unhappy somehow.
ICON Motorsports
Old Aug 2, 2001 | 06:19 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
well mines an automatic so i think it will b ok.....what if i had a 2500 stall on it...would that hurt it??
and yah i know i see these people with the same thing as me and they are runnin low 15's....i think my car is way outta tune.....im gonna get some money together and take it to a shop with a computer and have them tune it all back up
and on that 15.986 run my carb bogged right b4 i shifted into D so i guess i need to fix that too and it will b faster
Old Aug 2, 2001 | 06:20 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
oh and i dont have the dual snorkel if that makes any difference....its just the single snorkel hooked up to the tube taht gets the "cold air"
Old Aug 2, 2001 | 06:24 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
A few improvements you can make:
All new bearings, use a crush sleeve eliminator on the pinion, late-model (28-spline) axles or even aftermarket ones such as Superior, posi to go with the axles, weld all the way around where the axle tubes go into the housing, housing girdle type of cover with cap braces, synthetic fluid
ICON Motorsports
hectre13
Dec 11, 2023 08:14 AM
AkDrifted
Aug 17, 2015 07:45 PM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
3rdgenparts
Aug 6, 2015 09:03 AM
