Engine Hesitation
Old Jul 26, 2001 | 12:56 AM
JoshDT91's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 2.8L V6
Engine Hesitation
I have a 88' Camaro with the 2.8L. I have done pretty much everything I could think of that is simple to remedy this hesitation.
The problem is when I first start the car for the day and press on the pedal it doesn't respond right quick. It takes it a while and thinks about it then it kicks in abruptly. However, once the car is warm the problem has gone away and is never seen till the next day when the car is started again after sitting for hours.
These are the following things I have done. I have changed plug wires, plugs, dist. cap, rotor, adjusted the tv cable, and replaced the O2 sensor.
I have noticed some greasy stuff on the back of the passengerside engine head. However I don't know if this is oil or possibly transmission fluid that once spilled out. No oil spots are ever seen under the car although the car does use about a quart or so between oil changes. I do hear a noise sometimes that sounds like something blowing through something. Well any help is appreciated guys.
2.8L V6 173ci
K&N Air Filters
JET Underdrive Pulleys
Old Aug 2, 2001 | 06:38 PM
alexrela's Avatar
Only two things comes to mind. coolant temp sensor, TPS need ajustment or replacement.
'91 Camaro 3.1 t-tops 44k original.
'98 GMC Sonoma excab 4.3 auto 35k.
Old Aug 2, 2001 | 06:41 PM
One Eyed Jack's Avatar
its gotta be a sensor problem. You changed O2, I'd check coolant sensor then other ones.
Old Aug 2, 2001 | 09:45 PM
JoshDT91's Avatar
Engine: 2.8L V6
Well guys thanks for the ideas, but right now my car has taken a trip to the local Chevy dealer cause the engine will not start. The engine cranks, the spark plug wires make a spark, and the exhaust has back pressure, but it will not start. I am having them fix the car tomorrow so maybe this hesitation is part of what they will fix. Thanks for the help.
2.8L V6 173ci
K&N Air Filters
Ikes 91Z
Dec 9, 2015 03:49 PM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
