question concerning friends ***** CRX?
Old Aug 2, 2001 | 09:59 PM
84IROC's Avatar
after starting the engine when the AC is engaged the idle drops off considerably and furthermore when the head-lights are turned on and the AC is on the engine has a tendancy to die...
Old Aug 2, 2001 | 11:20 PM
92fire-audio's Avatar
To me it sounds like the alternator is going out. Does the car have a voltage meter? If so, watch that, if it's fine until you turn some accessories on then dips down, it's probably an alternator.
Go to autozone or wherever and have them check it. I had a bad one that was only putting out about 15 amps, which is not nearly enough.
hope that helps.
Old Aug 2, 2001 | 11:32 PM
breathment's Avatar
or, maybe if the RPM's are going to far down, then it could cause those problems. Plus, A\C's are realy hard on those 4 cylinders. Check the idle compared to that on the sticker under the hood. i had my acura idleing about 600 and it seemed to dip to 500 or so with A\C on.
88' GTA 350 MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass
chazman
Aug 28, 2018 03:25 PM
lt1z350
Aug 28, 2015 05:57 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
chazman
Aug 22, 2015 02:01 PM
redmaroz
Aug 16, 2015 11:40 PM
