car overheated bad, future problems?
Old Aug 2, 2001 | 03:23 AM
berlinetta84's Avatar
just bought a 92 RS with the 305 tbi in it. first drive i took with it was to the gas station. i always leave my cars running at gas stations while im filling up, so i went in, paid, then took off again just to see my temp gauge was pegged because the fan didnt come on. so i parked it in a nearby parking lot, opened the hood, and it was boiling into the resivoir. i dont know how hot it got, just that it stayed boiling for about 5-10 min. so what i need to know is what major problems might come from this, and what should i look for? dont worry about the fan i am getting that fixed.
Old Aug 2, 2001 | 12:21 PM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
I am not really far from you. I am in Glenwood so if need be I can show you or you can call/email me. I say this because when I first bought my LG4 305 carb I had the same problem. Several things need to take place for your car to run right, especially in the heat/COLD we have had around here.
1. Radiator can not leak. I put in a new one the first week I had my car. Don't go rebuilt, get a NEW one.
1a. Fresh anti-freeze all the time.
2. Fan relay must be working for fan to come on. Mine is located on driver side firewall but I have a '86 so it may be different on yours.
3. Need that plastic fan shroud. It controls air flow to the radiator.
4. Thermostat should be replaced. This way you know what you have. I have a 160 degree t-stat which is good for city driving/stop & go. If you do aa lot of highway then you want the higher rated t-stat.
5. If yiu have the idiot lites get a aftermarket guage. You need to see the temp of your engine at all times. By the time the idiot lite comes on it's too late. I had one put in for about $100.00. Chevy ran it direct to my block thru my A pillar pod. Looks sweet along with a tach and oil pressure. And I still have the idiot lites to boot. With you having a '91 RS I bet you have the guagues. Once you know what degree t-stat you have in your car then you can tell what temp your engine is. All you have to do is let your engine idle and the fan will kick in when the temp reaches the same temp as the type of t-stat you have in your car.
6. Be prepared to replace your water pump also. If this is not pumping properly you can seriously damage your heads or block. Check for leaks.
Now I am no mecanic but I had to go thru all of the above steps to solve what sounds like the same problem you have.
REMEMBER THESE F-BODY WILL OVERHEAT VERY EASILY IF ALL OF THE ABOVE IS NOT IN PROPER WORKING ORDER!!!
HOPE THIS STUFF HELPS! eMAIL ME IF YOU NEED MORE HELP.
86 Camaro Black SS Coupe, T Tops, Flowmaster, Custom Paint, Dunlop Road Kings S/R tires, Wheel Country Directional Chrome Wheels,new charcoal & gray interior including seats and door panels, new carpet and headliner, complete front end suspension rebuild, new Valve seals, and more mods to come
http://www.angelfire.com/sports/niterider/86camaro.html
Morgan_Andre@hotmail.com
Old Aug 2, 2001 | 01:24 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Overheating can cause a blown head gasket.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER, NO CAT
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
2:73 GEARS
Rebuilt 700R4, with manual valve body
B&M Megashifter, 5" Autometer Tach w/shift lite
Soon to be installed
3:73 Richmond Gears and 3" Hooker Aero Chamber
Corvette Servo & .500 boost valve
15.61@ 95.2mph G-Teched, 1-2 shift slippage, and just replaced a burnt plug wire
"There is nothing more addicting than speed"
Old Aug 2, 2001 | 02:03 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
hey not to get off the subject but is that hoffman estates near park forest and saulk trail??
84TA T-tops L-69 305HO TH-700R4 stock 190hp and 240 ft-lbs.
new best E.T. (dont laugh) 15.986 @84.93mph
old best E.T 15.997@86.04
http://www.geocities.com/K_towngangsta
Old Aug 2, 2001 | 07:44 PM
iroc5speed's Avatar
the thermostat has nothing to do with when the fan comes on. there is a fan switch on the side of the heads(right head). stock temperature is 220 degrees. the thermostat only regulates the flow of coolant.
Old Aug 3, 2001 | 12:38 AM
FlashGTA
Guest
Posts: n/a
A very strange problem that can happen and yes it happened to me is that the overheating actually weakens the hold the head has on the rocker stud and since they are pressed in they just start pulling out. Suddenly your adjusting valves a lot and you wonder why until you find out the hard way. If you start getting any valvetrain noise beware! An easy and cheap fix is to drill the base through the stud and head and install a roll pin to hold the stud in place.
1992 Trans Am
May 10, 2023 07:19 PM
86IROC112
Apr 9, 2016 10:20 PM
mustangman65_79
Sep 1, 2015 03:51 PM
mustangman65_79
Aug 8, 2015 12:07 PM
Newguy91rs
Aug 7, 2015 09:51 PM
