blower motor
Old Aug 2, 2001 | 10:13 PM
highhat's Avatar
blower motor
tonight I changed plug wires cap rotor doing plugs tommorow my question is earlier in the day my ac was blowin just fine but, after the afore mentioned was done went for a drive turned on the A/C and the compressor kicks on but no fan what gives?
Blue 1989 IROC Z28
Old Aug 2, 2001 | 10:25 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
You might have knocked off the power wire to the blower motor.
I would check that first.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
Old Aug 3, 2001 | 06:14 AM
highhat's Avatar
where is it located?
Blue 1989 IROC Z28
Old Aug 3, 2001 | 08:43 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
The blower motor itself is located on the passenger side firewall (bulkhead? talk to ralph nader about that one) on the heater box itself, just to the right (while sitting in the car....) of the evaporator case. There is a single wire connector to is. There is also a multi connector on top of the case, right next to the evaporator housing. Check that one also.
Old Aug 3, 2001 | 01:55 PM
highhat's Avatar
Thanx fixed it right up, thank god it's hot as h*** here.
Blue 1989 IROC Z28
Frozer!!!
Jan 19, 2024 04:55 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
zayne0
Aug 24, 2015 07:22 PM
mhatfield 14
Aug 15, 2015 10:47 AM
Street Lethal
Aug 13, 2015 08:28 PM
