which camaro should i get?
an 88 TBI 5.0 5spd 123k iroc-z body needs a little work interior is good, or an 83 with a mildly built 350 1k that doesnt run up to par and has a bad interior and a th350 that doesnt shift into third. the 88 is going for $2750 and the 83 is going for $2500. thanks for any help
Car: camaro rs
Engine: 305 tbi and 350 on stand
Transmission: 4spd auto
both sound overpriced. at least they are if they were being sold over here on the east coast where even nice looking camaros can be had for under 2k.
Car: '86 Berlinetta
neither IMO, but I'd probably get the one with the 350 in it, just because swapping to a 350 later on is ... expensive and time consuming to say the least.
Interior you'll be able to replace for much cheaper. The trans you can find the proper one in a junkyard for not too much, or if you want a T5 then you can always buy one from a aftermarket vendor... either way you'd have the performance aspect heh.
Make sure it's a 350 is all that I can say really. Go to www.mortec.com and look at how to check the numbers. That way you arent being jipped.
84z96L31vortec
Aug 20, 2017 12:16 AM
