key doesn't spring back from crank
Old Apr 16, 2005 | 11:31 AM
jasman19's Avatar
Car: RED 1986 IROC-Z28
Engine: 350 5.7L
Transmission: TH 700R4
Axle/Gears: 3.23 10 Bolt
Heres my story, I took apart my steering column to tighten the four back bolts because my tilt was loose. After I got it back together I noticed that when I try to start my car the key doesn't go back to run. I checked to see if something was missing and the only thing I found was a metal clip (not sure what its for). I checked the parts schematic and didn't find it on there. Not sure whats up but I can't figure it out. Hope someone on here has had experience with it.
thanks
Jason
Old Apr 16, 2005 | 12:40 PM
jasman19's Avatar
Engine: 350 5.7L
I ripped my column back apart again so that I can get a second look at the locking cylinder and the cam on the other side. Does anyone know how the spring on the cam is suppose look like? Thinking that I might have bent it when I tried to take the tilt off. Not sure but if someone know how it looks would be a big help. Right now the spring has an end that goes into a track looking recess on the side of it. The spring just makes contact with the end of the track when I start to turn the key to crank. But instead of it putting tension on the cylinder it just bends back. Hope that helps a little more.
Old Apr 16, 2005 | 02:25 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Try a search with username "Vader" and steering column...he's posted several PDF's of the columns breakdown, might help ya out some.
Old Apr 16, 2005 | 06:05 PM
jasman19's Avatar
Engine: 350 5.7L
appreciate it, I checked on it and found some info that helps. Wish I had a pic of how the spring looks just to make sure. I seen the diagram that vader posted and it had a good pic of it.
I'll try messing with it again tomorrow and if it doesn't work then I'll try and get another one.
thanks
Jason
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Jae992
Aug 27, 2015 09:07 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
dhonda200
Aug 11, 2015 11:50 PM
