failed emissions big time help!
Old Aug 3, 2001 | 06:17 PM
HIX5000's Avatar
Hydocarbons passing- 1.60, what I got- 3.55
Carbon monoxide passing-15.00 what I got- 21.99
Oxides of Nitrogen passing- 2.50 what I got- 5.95
I failed every test by a lot. Where should I start? Are these really bad numbers or fairly common? Any help is greatly appreciated.
1988 Camaro RS
2.8L five speed
Gutted airbox
accel cap and rotor, crane cams 8.5mm wire
TB bypass
stop laughing you gotta start somewhere.
www.angelfire.com/briansnaughtylittlepage/
Old Aug 3, 2001 | 06:21 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
cat
ICON Motorsports
Old Aug 3, 2001 | 06:27 PM
HIX5000's Avatar
Would it be better for my emissions to get a regular cat from an auto parts store or should I order a catco high flow cat from summit?
Old Aug 3, 2001 | 06:36 PM
un4givin89's Avatar
I ripped my cat off, I could car less about globel warming and tree hugging liberals and the dolphins.
Look at those numbers in pride!
Old Aug 3, 2001 | 06:40 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Also, your O2 sensor may not be "up to snuff" if it is old. O2 sensors are notorious for working well enough to not trip an SES code, but they are weak enough to not give an accurate reading.
Also, when is the last time you did a tune up? You need to give more info.
Have you cut the screens from your MAF sensor BTW?
Old Aug 3, 2001 | 06:44 PM
HIX5000's Avatar
The plugs, wires, and O2 sensor have less than 3,000 miles on them. I didn't cut the maf screens.
Old Aug 3, 2001 | 06:56 PM
Car: Death Mobile
Engine: 666 c.i.
Then I would go with RB's recommendation of new cats.
Old Aug 4, 2001 | 12:15 AM
iroc5speed's Avatar
you could always install a dual cat setup with high flows-thatg would cut emmisions further.
'86 IROC 5-speed
305 LG4
edelbrock performer rpm intake
edelbrock 600 cfm carb
msd pro billet hei
'95 3.23 rearend
hotchkis rear suspension
Old Aug 4, 2001 | 12:17 AM
One Eyed Jack's Avatar
un4given, you bastard
Yeah I'd check O2 sensor, and cat. If you're still not doing good you're probably burning oil and/or antifreeze.
89GTAOz
May 16, 2020 09:31 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
69 Six Pack
Oct 5, 2015 07:51 PM
theurge
Aug 21, 2015 12:46 PM
sreZ28
Aug 14, 2015 07:48 PM
