Funny exhaust color
Old Aug 3, 2001 | 02:49 PM
84IROCz28's Avatar
Funny exhaust color
What does it mean when your car blows bluish/white smoke from the muffler?
Old Aug 3, 2001 | 03:05 PM
TorchTA's Avatar
Uhmm....burnin a bit of oil?
My 86 does it too....
someone mentioned something about bad valve seals....'tever those are.
-JT
Old Aug 3, 2001 | 08:21 PM
EvilCartman's Avatar
Car: '82 Z28
It just means you're running a well broken in Chevy motor Unless it's a lot of smoke, then you might have a slight problem.
Old Aug 3, 2001 | 08:31 PM
84IROCz28's Avatar
<font face="Verdana, Arial" size="2">Originally posted by EvilCartman:
It just means you're running a well broken in Chevy motor</font>
I just hope that it's not a well "broken" chevy motor. I've got a lot of problems going on with it, including a persistant oil leak from one of my valve covers, no matter how many times I change the gaskets, and tighten the bolts.
Old Aug 3, 2001 | 09:10 PM
Damon's Avatar
Unless the plugs are getting loaded up with oil don't worry too much about the occasional puff of bluish smoke. Normal for old Chevy motors to get a little "loosey goosey" up around the valve guides/seals. Constant smoke while idling or a big puff every time you pull away from a stoplight could signal more serious problems, however.
Old Aug 3, 2001 | 10:31 PM
84IROCz28's Avatar
If it puffs smoke after a take off, what does that intail?
Old Aug 4, 2001 | 12:23 AM
rezinn's Avatar
When you accelerate? Sounds like piston rings. If it smokes at startup, thats leaking valve seals.
Old Aug 5, 2001 | 12:46 AM
84IROCz28's Avatar
Sh!tty day. Sounds like I may have some work ahead of me. It's not too bad, it just smokes real bad every time I take this steap hill, and accelerate up it. Any thoughts?
Hotrodboba400
Dec 10, 2019 07:07 PM
angel2794
Sep 8, 2015 06:22 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
