Distributor off a tooth?
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
When I took my car to a mechanic he said my distributor was off by a tooth. First, i don't even know what he means by it and second, how do I know if i need to move it clockwise or counter-clockwise? I am still in my fight to lower my HC output to get my plate. Thanks
1 Post
Car: 1992 Camaro RS
Engine: 355
Axle/Gears: 3.73:1
The only way it can be off a tooth is if it has been taken out before. The best way to check is with a timing light. If the timing is too far off to adjust by rotating the distributor, you will have to pull it up and set it back in place after turning the rotor a slight amount. If you need more details on this just let me know.
even if it is off you can usually still set the timing. only if it hit or binds up on soething would you need to take it out and move it, and before you go to that much trouble you could move the wires one post over on the cap.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
ICON Motorsports
1st & 3rd
1 Post
Car: 1992 Camaro RS
Engine: 355
Axle/Gears: 3.73:1
Hmmm, yeah, ignore what I said, do what ede said. It will work fine, I put my distributor in backwards once and just moved the wires (don't laugh )
So the only negative impact the distributor being off a tooth is not being able to set the timing? I currenty have it set fine at 8dec BTDC
hell if you have the timing set there is no problem as long as you have room to move the distributor to make small changes if you want.
ICON Motorsports
1st & 3rd
ICON Motorsports
1st & 3rd
Valpo,
To dig a little more deeply, your high HCs may be more a function of a rich mixture, cold engine, or malfunctioning Air Injection system. As long as the ignition timing (base timing, of course) is correct, you should start looking elsewhere.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Later,
Vader
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
Hello,
It doesn't really matter how you put your dist in, as long as you based piston 1 at
TDC.. The rotar turns, finish the firing order.. set the timing..
-- Joe
-- Joe
RedLeader289
05-28-2019 01:47 PM
Damon
09-26-2015 04:29 PM
