What is shrouding
Old Apr 19, 2005 | 09:54 PM
Breazlan's Avatar
Car: 88 Firebird
Engine: 302 SBC
Axle/Gears: 4.27 Dana 44
What is shrouding
What is considered shrouded or unshrouded in a valve to chamber relationship? Is there a formula you use when taking measurements? How are measurements taken?
Old Apr 20, 2005 | 12:12 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
if you have looked at a combustion chamber with the valves in there you should see that there in the depression that makes up the combustion chamber where the valves sit. around the valves you have quite a bit of open space but usually part of the valves sit right on the wall of the combustion chamber also.
so even when the valve opens up since the wall of the combustion chambe ris right there it's not able to really let any air through there.
what valve unshroading is is taking that part of the combustion chamber and remove some of it so this way you have more open area around the valve so it is able to breath a little better.
one downside in doing it though is since you are removing material from the combustion chamber your effective compression ratio goes down a little as well
as far as forumula I don't know of any myself but hopefully a few of the others here might be able to help you with that
Old Apr 20, 2005 | 01:12 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
there is no real "measurement", like grind for 10 mins and remove 1cc
that would be tough to calculate...
When you're done unshrouding, put plexi or something on it, fill it with liquid and measure the liquid.. that's the common way to cc a combustion chamber...
do a search for a more descriptive.... description
Old Apr 20, 2005 | 08:15 AM
Breazlan's Avatar
Car: 88 Firebird
Engine: 302 SBC
Sorry, I will clarify to put this on track. Main question is: What is considered shrouded? ex: A 1.94" valve has a radius of .97" and should have a clearance radius of x.xx" I would like to measure my heads and see where I am at and if larger valves will cause a shrouded condition. People say this is shrouded and that is shrouded, how do they know? I am assuming when they say this they mean big negative effect.
Another issue:
I see sometimes the comment, "A 1.94" is already shrouded so going to a larger valve does not help." As it has been explained here, a portion is shrouded. Would the unshrouded area increase in flow with the larger valve? The shrouded area shouldn't matter much with the larger valve as it is already cut off. Would this be a correct comparison: A larger valve can flow more than a smaller valve, both unshrouded; a larger valve can flow more than a smaller valve, both shrouded.
Old Apr 20, 2005 | 09:19 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Standard Abrasives website mentions 3/16th clearance, but not to infringe out of the bore.
IIRC, FBird88 (I believe) did post a formula, but I never saved the thread ID.
Old Apr 20, 2005 | 01:48 PM
Sonix's Avatar
Car: 1982 Trans-Am
chances are, F-bird88 knows more about this... and if you're really lucky he'll post up a nice little paint picture showing how a larger valve does have more flow area on the inside area, but also that more area is now shrouded, *minimizing the gain*...
So yea, larger valves are always better, but the shrouding makes it not really worth buying the bigger valves for the small gain...
Just to get as much info as possible here to help the most:
What heads?
What valves were you considering? 1.94? larger?
What kind of powerband were you looking for? full out race-high rpm? just around town?
budget?
just if you wanted more help with your application...
Bubbajones_ya
Jul 6, 2024 08:32 PM
codeysabatini
Nov 10, 2015 04:07 PM
randy210
Oct 15, 2015 03:43 PM
krisner89
Oct 10, 2015 06:03 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
