Help me with ideas please
Old Aug 6, 2001 | 10:54 AM
Synergy's Avatar
I know this is a classic "dillema" and has probably been covered numerous times, but I want to ask again.
I'm building a 383 for my car. I aquired a 92 roller block. I have a set of 64cc aluminum TF 23 degree heads a 270-HR10 cam right now. I also have a stock TPI with a superram base, but I plan on buying siamesed SLP runners.
Who sells one peice 383 cranks ? Should I have the machine shop clearance the block ? Do I need 6" or 5.7" rods ? What else is different then a 350 ? A 383 is a 350 bored .030 over right (with a different crank of course). Thanx in advance.
92 Z28 5.7
Trick Flow 23° heads, Comp Cams XR270HR-10 cam, Accel intake base + ported TPI,
TES headers, Flowmaster catback, MSD ignition, #24 SVO injectors, 1LE aluminum driveshaft.
Click here to see pics of my car !
Old Aug 6, 2001 | 11:36 AM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
Yes, a 383 is an engine with 4.030" bore and 3.75" stroke. Check out www.sdpc2000.com for the crank. They've got a pretty good array of stroker cranks ranging from cheap cast ones all the way up to the bulletproof 4340 forged variety.
-Mark W.
'88 SC Camaro w/ 305 TBI
Old Aug 6, 2001 | 11:41 AM
Synergy's Avatar
Thanx
Do you guys think the cam I have now is good enough ? Should I got with more duration or lift ?
Old Aug 6, 2001 | 11:46 AM
RW91B4C's Avatar
Scat sells a one-peice, and so does Eagle.
I got the scat strocker kit, a cast steel crank, 4340 rods, SRP pistons. Get the machine shop to clearance the block - its cheap. If its a daily driver or will see alot of miles - go with the 5.7 rods, this enables you to use a piston with a taller skirt which will have less wobble. I dont know if you can use the same cam, you may have to have a cam ground with a small base circle to clear the rods.
91 B4C 305 TPI - SOON TO BE 383
TREMEC 5-SP, STOCK 1-BOLT REAREAND w/342 GEARS, K&N, AIRFOIL
EDELBROCK HEADERS, DUAL CAT TO HOMEMADE Y-PIPE & 3.5" SINGLE PIPE W/ FLOWMASTER, CRANK PULLEY, MSD, FUEL PRESS REG, COWL HOOD, WELD WHEELS
14.1@ 98MPH
OTHER RIDE
67 CAMARO - STREET CAR, BIG BLOCK, PUMP GAS
350TH w/ATI 10", 12-BOLT w/373 GEARS
10.94@124.13 ON MOTOR - ET-STREETs w/MUFFLERS
gta892000
Aug 11, 2019 11:16 AM
Fox118
Sep 12, 2015 09:29 PM
Nick McCardle
Sep 10, 2015 08:36 PM
Djmathis123
Sep 8, 2015 08:42 PM
