new thermostat and running hot!!!
Old Aug 6, 2001 | 10:35 AM
carter89RS's Avatar
I put a 180* thermostat this weekend and she runs great on the highway, but when i get into stop and go traffic she gets up to 260*!! what could be wrong?
Old Aug 6, 2001 | 01:06 PM
Vader's Avatar
89,
There are a few possible problems at work causing your high temperatures at low speeds:
1. Poor water pump performance;
2. Inoperative or failing electric fan (brush and commutator wear will cause slow operation and poor air flow);
3. Excessively lean mixture and late spark advance at idle/low RPMs;
4. Your car was never designed to idle in traffic anyway - you need to be moving at about 140MPH whenever you can to promote good air flow (j/k) .
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Old Aug 6, 2001 | 02:16 PM
Third's Avatar
Hey Vader, don't you think running that fast is a bit excessive?
Old Aug 6, 2001 | 02:19 PM
LottaBallsCamaro's Avatar
Did you install it backwards?
Old Aug 6, 2001 | 03:32 PM
carter89RS's Avatar
the thing is it never did this with the old 195* thermostat.....
theshackle
Mar 5, 2017 06:37 PM
ezobens
Aug 19, 2015 10:29 PM
jackhammer
Aug 15, 2015 10:04 PM
perZ
Aug 15, 2015 01:17 PM
