Roller rockers on a 305 with LT1 cam?
Old Apr 20, 2005 | 05:13 PM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
I have these mint condition Comp Cams pro magnum 1.6 roller rockers I've been sitting on for the last 4 years. They were used for about 1000 miles. Screw in studs, hardened pushrods and guide plates too. Put them on a friends LT1 just before he had to move and couldn't take his car. He gave them to me for helping him so much with his car.
Took them off again and they sat ever since. Wanted to see that car go down the drag strip but never got to. We done loads of mods on that car.
Anyways, I was doing a stock 305 TPI rebuild and was wondering if I can incorporate the 1.6's into it somehow with the LT1 cam. Is there a spring I can buy that will work in stock configuration? I know I would have to have the stud guides tapped but I don't want to do much more with these crappy 305 heads.
Perhaps I am losing my mind. Keep the 1.6's for at least a 350.
Opinions or solid advice welcome.
Old Apr 20, 2005 | 10:08 PM
Engine: SBC, LS-x
Flame me if you like. Any answer is better than no answer.
Old Apr 20, 2005 | 10:23 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No reason you can't. Just make sure you have clearance between the retainers and the valve guides.
Comp 981, or the rough equivalent Crane, Crower, Isky or Lunati 1.25" springs, would be adequate. I'd avoid "Z28" springs and any other GM ones, and K-Motion. Get them from one of the major cam mfrs.
Also, make sure you have the right combo of self-aligning rockers or not, guide plates or not, and slots in the heads or not. Only one alignment method can be used at a time.
Old Apr 20, 2005 | 10:57 PM
Engine: SBC, LS-x
Comp 981
That is the exact spring we used on the LT1 when we done it. They stayed along with the headers and a few other harder parts to remove.
How much clearance would you consider safe?
Old Apr 22, 2005 | 07:08 AM
Nathan Plemons's Avatar
Car: 1992 Chevrolet Corvette
Transmission: ZF-6
Actually just as a side note you can run self aligning rockers and guide plates at the same time if everything lines up right. There's no real reason that you would really WANT to, but you can. I ran my engine like this for a long time before I finally ditched my 1.6 rockers in favor of non-self aligning 1.7's. I had no bent pushrods, no excess wear on the guide plates or pushrods.
midge54
Dec 27, 2019 04:14 PM
Mickeyruder
Sep 2, 2015 02:45 PM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
IrocZ'85
Aug 17, 2015 06:24 PM
